It states that i have no optical drive while my optical drive is functional.
It also does not say anything about my operating system apart from the fact it is 64bit.
Your Speccy version is almost 6 months old, you should try updating to the latest version (currently 1.25.674 (29 Jan 2014)).
Did you run Speccy as an Administrator? Are you using installed or portable version?
