A few easy questions
1. In 1963 if you went to bed at 8.00 and set the alarm to get up at 9.00 next morning, how many hours of sleep would you get?
2.How many sides are there in a circle?
3. Some months have 31 days, some have 30 days. How many have 28?
Ok I'll have a go.
1:25
2:None
3:12
1. 1 hour.
2. 1 (continuous)
3. 12
1. 1 hour because an alarm clock wouldn't know to only go off on the next day.
2. 1 if only counting either the inner side or the outer side. 2 if counting both the inner side, and the outer side.
3. 12.
1)you cant set the alarm after your sleeping.
2)2, top and bottom.
3)12, they all have at least 28 days.
those are some good ones...
Off on holiday in an hour so here are the answers
1. 1 hours sleep. The 24 hour clock was not in general public use then!
2. 2 inside and outside!
3 12 all months have 28 days.
1. you cant set the alarm once your sleeping
2. 1 continuous
3. 12 all months have at least 28 days
-devin
