A couple of questions
I got thinking, and the question popped into my head.
In eraser you have to option to erase free space, when thinking of this i wondered how the different passes "stacked" on eachother. Say you want to erase your freespace with 40 passes as a example, would it make a difference if you sperate the erasing as 4 10 pass erases?
Say you do a 10 pass psedorandom data free space erase at 4 different times would it be the same as doing one 40 pass pesodorandom data free space erase?
Would it be the same level of data erasing if you did the 40 passes at 4 different times?
This just popped into my head, and i always want to learn about this kind of stuff its interesting to me.
Another but minor question, what do you think is better as a image viewer?
XNview, or Irfanview?
Thanks!
Thanks!
Both are good. According to the IrfanView website XNview has been copying the IrfanView feature-set for years, make your own judgment on that though.
