1) In both XP and 2 Windows 7 machines, Benchmarking drives, both SATA main and USB connected clones, returns very unrealistically low results after defraging. If Defraggler is restared and the drives reanalyzed then realistic results result.
2) In XP the SATA connected clone keeps showing all the unused disk space between the main used area and any used space further out as MFT reserved? This can go away after an upgrade but then will return with use? It doesn't affect the drive, which will boot and operate normally. It's just annoying as unexplained\weird.
Thanks: DES
