6950 Temp Not showing
Hello everyone, first of all I wanted to say that I really like the program and I normally use HD monitor, cpz, etc. for my monitoring programs. I would like to switch to Speccy because it has everything I need in one and it provides more information as well. My problem is that the temperatures are not showing for the graphics portion of the display. I will post my Speccy and let me know if you need any additional information. It does appear from reading a few other threads that my card just may not be supported at this time, as a few others reported different video cards with the same issue. If that is the case please let me know, if not please let me know what I can do for it to display correctly. My video cards are reference model 2X MSI HD 6950 2GB GDDR5 in Crossfire. They have not been flashed or overclocked as of yet. MSI MODEL R6950 2PM2D2GD5.
Operating System
MS Windows 7 Home Premium 64-bit SP1
CPU
Intel Core i5 2500K @ 3.30GHz 28 ?C
Sandy Bridge 32nm Technology
RAM
8.00 GB DDR3 @ 798MHz (9-9-9-28)
Motherboard
Gigabyte Technology Co., Ltd. Z68X-UD3P-B3 (Socket 1155) 29 ?C
Graphics
HP 2310 (1920x1080@60Hz)
AMD Radeon HD 6900 Series
Hard Drives
977GB SAMSUNG SAMSUNG HD103SJ ATA Device (SATA) 29 ?C
Optical Drives
Optiarc DVD RW AD-7260S ATA Device
Audio
Realtek High Definition Audio
Graphics
Monitor
Name HP 2310 on AMD Radeon HD 6900 Series
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State enabled, primary, output devices support
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Memory 4294965248 MB
Memory type 2
Driver version 8.850.0.0
Memory type 2
I just downloaded the program, so I am sure I have the latest edition. Thank you in advance for any help, and I just wanted to again say that I think your program is great!! I just need those GPU temps :)
