64Bit vs 32bit
I have a 64 bit computer with Windows Home Premium.
Might seem like a dumb question but should I be using the 32 or 64 bit version of CCleaner?
James
"quoted off the ccleaner download page"
Runs on Microsoft Windows 7, Vista, XP and 2000. Including both 32-bit and 64-bit versions. "of the operating system, ccleaner has no different download for 32 or 64 bit".
Last I heard also, I thought piriform dropped 2000 support, but it's still listed on the page, because some old versions work with 2000.
The portable ZIP will give you both CCleaner.exe and CCleaner64.exe
With both on a flash drive it makes no difference which you launch - the correct one for the system will operate.
If you delete the correct one the other will run but may miss some of the things that would otherwise get zapped.
I guess if you install the installer will make the correct decision on which flavour to install.
Got it.
Thanks,
James
