64 Bit Recuva Beta
For those of you with 64 bit OSs :) This is in the final stage of development, so I'm interested in hearing feedback on performance and any other interesting things you find.
MrRon
Recuva64_Beta.zip
Recuva64_Beta.zip
I just tried a normal scan, the 64-bit one is a bit faster :lol: (64 bits : 12s, 32 bits : 15s)
A 64 bit Defraggler would be great (but I think you already imagined that, didn't you ?)
Yes, we are working on 64 bit versions of all our products :)
Could you please upload the beta again? Winrar is showing the file to be corrupted: end of file error. Thanks
MrRon
Can't download, file is corrupt..... :(
I use 7-zip, it works...Winrar is corrupt, not this file :lol:
I didn't use winrar, de ZIP-file itself was corrupt.
For some reason IE8 is corrupting the files downloaded from the forum. If you have this problem then please use a different browser.
MrG
MrG
It worked with Firfox, thanks.....
Just one more question (sorry if my English is not that good, i'm from the Netherlands);
When i start the 64-bit version, it tells me that there is an newer version. Is this also a (newer) 64-bit version or is this the 32-bit version?
If it is the newer 64-bit version, why isn't that one in this topic?
Don't work with 7-zip either
No, there is no newer version of the 64 bit version, you can ignore the update notification :)
MrRon
MrRon
OK, thanks
