I've been using the Issues Feature of CC128 for a good while. Fixing always worked. Today over 600 issues are identifies but they are not removed. Went to Safe Networking Mode as Administrator and downloaded a fresh copy of CC Cleaner 128. Still does not remove any of over 600 issues. What to do?
Al
Try Dial-a-fix > Tools > Repair permissions
DjLizard's instructions will probably work, but I have a different concern.
Has it been a long time since you've used the Issue option? I'm concerned about the amount of options that you're trying to fix. Why do you have 600+ issues identified?
A lot of software had been uninstalled. On most machines I see between 200 and 2000 issues (and then subsequent scans show 200 to 2000 more). Worst machine I ever saw had 6000.
OMG!
I get excited when I find 2 issues. (My computer needs to get a life)
i am new to cc---have had it about a month with good results...until yesterday when all of a sudden i came up with 30 plus issues which keep showing up after a boot. and this thing with the ie7 uninstaller is a big mess. arrgghh....i mean it is nice that someone keeps posting that the hotfix option does not work with ie7...but it was way after the fact that i saw the posts. i think that at least subscibers should get an email about the obviously well known bug...... if there is anyone in particular to whom i should address my concerns, please let me know. good,--sigh, i fee better already.
Did you repair your permissions?
