5.61 Update Problem
When I tried to use the 5.61 installer it bypassed all installation options and immediately began installing. In particular it apparently installs to its own default system folder in spite of a prior installation elsewhere. To prevent the installation I had to kill it from task mgr because the only option was to allow it to 'finish'. Previous installer versions have worked properly.
The 5.61 slim build installer is working properly.
Was this a fresh install, or on top of a previous CCleaner version. Also, which Windows OS version are you using?
