I have reinstalled 5.46 twice with the same result. (Doesn't empty recycle bin from "run ccleaner" in context menu.
Each time I have reverted to 5.41 which, as far as I can see, works correctly.
Running Windows 10 Pro 1803 with all updates.
The developers are aware on the context menu issues; I believe that they are working on a fix for next release, but have no proof of this.
Please see the latest Beta release which should fix this issue
