Try to update your USB3.0 drivers, I had this similar bug where drives didn't get recognized properly. Update your USB3.0 drivers and then restart your computer. I'm assuming that you need Intel's drivers, here's the latest driver for you:
Chipset Family 8 is for the newest Intel's Haswell processors, and 7 is for older processor models. Make sure you install the right one because you get bsod.
Also remember to check your OS model, because these drivers are comfirmed working only on Windows 7 and up.
