3.04.1389 and Thunderbird
I use thunderbird 6.0b and I have separate cache locations for Fx and Tb. I don't think they're supposed to share a cache location
Possibly my mistake, then, and maybe I'll dig into it later. It's just that this problem only started, as far as I know, when they "aligned" TB with FF.
Now, with the most recent versions of FF and TB, I have problems with CCleaner pulling the cache out from under TB if I run CCleaner with TB open - particularly images in mail messages or RSS feeds, and Thunderbird does not seem to go back to the web for them. (Yeah, that sounds like a Mozilla issue to me, but here we are.) Previously, CCleaner would warn you if you ran it manually (but not with a recycle bin right-click, etc.) while Firefox was running. Perhaps it now needs to do the same with Thunderbird, for the same reasons?
Thanks, we'll look into this.
I see that this change was applied in a recent update - CCleaner now prompts before cleaning if I have either Firefox OR Thunderbird open. Thanks!
