[3.00.1303] Drive Wiper confirmation dialog is too small
There's not enough space...the second line (or, rather, the third one since the first one is split) doesn't show. Now French users have no way to wipe their drives.
Is it possible to force the dialog to have enough height, or should I remove the line break?
Thanks. We'll look into this.
Had the same issue, and fixed it by myself, deleting the wordwrap ( \n ) in my translation:
Bad:
ATTENZIONE! TUTTI I DATI PRESENTI SUI DRIVE SELEZIONATI VERRANNO DISTRUTTI!\nPer procedere, digita la parola %1 nella casella sottostante:
Good:
ATTENZIONE! TUTTI I DATI PRESENTI SUI DRIVE SELEZIONATI VERRANNO DISTRUTTI! Per procedere, digita la parola %1 nella casella sottostante
Yup. But for now no French user can wipe his drive :unsure:
