2 Problems (Probably bugs)
First: Install date is incorrect in Uninstall section (existed in previous version also)
Proof :lol:post-33461-1259243110_thumb.png
Second: Start Menu Shortcuts are not cleaned (in previous version also)
Proof :lol:post-33461-1259243227_thumb.png
And thank you for your great jobs.
To my knowledge CCleaner has never cleaned that area of the Start Menu which is supposed to house the most recently used programs. Then again I have my system configured different than the Windows default.
It does allow for the removal of broken shortcuts in places like:
%userprofile%\Start Menu\Programs
Well as I can remember it used to clean that ( on XP and Vista also) but that was long time ago.
I can check that if needed with older version.
Thanks in advance.
"This option will delete Start Menu shortcuts that are invalid (they point to files that no longer exist)."
as Andavari said, ccleaner does not clean MRU of the start menu
