CCleaner 2.19.900 is not cleaning my start menu shortcuts.
I uninstalled Daemon Tools and the shortcut remained in the start menu.
I ran CCleaner (with the Start Menu Shortcuts checkbox ) and noticed the shortcut was still there.
I think the idea behind Start Menu Shortcuts checkbox is it checks the short-cut to see if the file is available. If it isn't then it will delete the short-cut but if it is then is will leave it.
Check to see if the short-cut still works.
No, it doesn't.
If I click it, Windows tells me that the shortcut refers to a program that was moved or changed and asks me if I want to delete it.
