1809 Edge
https://www.ccleaner.com/docs/ccleaner/troubleshooting/how-to-disable-pre-launching-and-pre-loading-so-ccleaner-can-fully-clean-edge
There is no key for 1809
gpedit.msc only for pro
Any update on this?
Thank you in advance
:rolleyes:
They really should update that page with correct information, this is the second post where someone has noticed the error.
Here's the correct information:
https://forum.piriform.com/topic/53177-how-to-disable-pre-launching-and-pre-loading-so-ccleaner-can-fully-clean-edge/
