Hi Everyone!
I noticed today during a run that there are blocks of a light blue color on the map, but the Legend doesn't explain what they are as with the other colored block. Might want to look at that.
I've attached a capture for your review and conformation.
Also, as a side note I'm finding it rather annoying that the percentage complete indicator is off somewhat. It reports as 100% complete but Defraggler keeps right on chugging aways for minutes after it is indicated as 100% complete.
I always thought 100% meant that is was complete.
So, 2 quick things I've found, one an oversight and one a definite bug.
Hope this helps make Defraggler the best it can be and please change to command to start defragging to "Defraggle" would'ya. so it goes with the proggy name.
Thanks and glad to be here!
Prey
