[0x7FFC67E71780] ANOMALY: meaningless REX prefix used
Hi All,
I am running ccleaner from a batch file using the '/auto' switch and getting '[0x7FFC67E71780] ANOMALY: meaningless REX prefix used'.
Can anyone shed any light on this?
Thanks
g
Any more info?
Which operating system?
Which antivirus?
Does that error message only happen when you run CCleaner or does it happen whenever you run a command prompt?
EDIT>> some obscure info here.
https://social.technet.microsoft.com/Forums/ie/en-US/efd83b6a-dc86-4854-b05f-f484e1ed5596/anomaly-meaningless-rex-prefix-used?forum=winserverGP
Windows 10
norton 365
I have come to the conclusion that this is a windows 10 cmd / 64bit application issue.
If I run it from a Powershell script then there is no such notification. As far as I can tell ccleaner is still doing its thing when run from win10 cmd despite the 'Anomoly' notifications.
Thanks for the input nonetheless.
G
