GreenJelly Posted August 1, 2015 Share Posted August 1, 2015 I ran the cleaner, checked the option to remove the windows.Old files from a previous install. When it was done deleting files and my system restore files applications wouldn't run. On a restart windows wouldn't boot. Repair would fail. Restart fail. The DVD I created wont boot so now I am re-downloading it and going to try and burn it on another disk. Booted off Windows 7, got a "Boot Selection failed because a required device is inaccessible" on the installation. Im going to keep triing, and Hopefully the new disk will boot. If not I am going to Install Windows 7 and Abandon Windows 10 for awhile. I have always relied on CCleaner and found it to solve, not create problems. Unfortunately this is not the case and I can't recommend anyone run it on a windows 10 machine. Link to comment Share on other sites More sharing options...
GreenJelly Posted August 1, 2015 Author Share Posted August 1, 2015 Ran a partition magic boot disk and formatted the hard drive. Now the Windows 10 disk boots without problem. Very strange. 3rd Install of Windows 10 since release. I am finding it Highly unstable, with applications claiming support but also full of issues. Information on Google or Bing is very hard to find. I can not recommend Windows 10 to anybody but the most tech savvy individuals. This has been painful and if I didn't know what I was doing, this latest issues created by ccleaner would have ended with a potential change of hard drives or bricking my pc. I am NOT happy. Don't claim support if your product destroys the system it runs on. Link to comment Share on other sites More sharing options...
wlegard Posted August 1, 2015 Share Posted August 1, 2015 Same problem here. Ran latest version of CCleaner on my new Windows 10 installation. At first I couldn't connect to my network (wifi or hard wired). Restarted Win10 and now I can't even log in. I just installed an SSD a week ago after cloning the HD. Time to put the HD back in and reclone. If I wasn't a former IT jockey, I'd be lost. Fix it NOW! Link to comment Share on other sites More sharing options...
Zarilya Posted September 12, 2015 Share Posted September 12, 2015 Same thing just happened to me. Also the third install of Windows 10 now. Yay, Link to comment Share on other sites More sharing options...
