trium Posted April 26, 2015 Share Posted April 26, 2015 hi fans, i have a new service in w8.1 (perhaps for windows-7-users too) in preparation for w10... read this from microsoft/kb/3035583 http://www.heise.de/newsticker/meldung/Windows-10-Downloader-Tipps-zur-Deinstallation-2596770.html is this only a advanced notification-serivce (as in xp the support-end-notification tray icon) to tell me, if w10 available to download or i need this as "must have" to become w10 as upgrade? do i need this or can i also upgrade to w10 without kb 3035583? Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
trium Posted May 24, 2015 Author Share Posted May 24, 2015 an update for 3035583 from 14.05.15 not for download on microsoft download center, but only for direct download about windows update Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 24, 2015 Share Posted May 24, 2015 This update enables additional capabilities for Windows Update notifications when new updates are available to the user. It applies to a computer that is running Windows 8.1 or Windows 7 Service Pack 1 (SP1). Before you install this update, check out the Prerequisites section. seems like it just enables some sort of dialog telling you that there are updates available for the computer. Truth be told, I had forgotten XP used to do that. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
trium Posted July 9, 2015 Author Share Posted July 9, 2015 new KB 3035583 from 09.07.15 http://answers.microsoft.com/de-de/windows/forum/windows_7-windows_update/kb3035583-manuell-installieren/22875b6c-e314-4682-9467-670dd298de3b?auth=1 es ist nicht unbedingt notwendig die Windows 10 Reservierung durchzuführen, um das kostenlose Windows 10 Upgrade Angebot zu nutzen. Das Windows 10 Upgrade bekommst du auch ohne die Reservierung ab dem 29.07.2015. Die dann zu nutzende Webseite wird noch bekanntgegeben. it is not absolutely necessary to perform Windows 10 reservation to use the free Windows 10 upgrade offer. The Windows 10 upgrade you get even without reservation from 29/07/2015. The then-to-use website to be announced. perhaps delete kb 3035583 one icon less in taskbar Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
