SAT31 Posted March 24, 2015 Share Posted March 24, 2015 Hello! I have ultrabook Dell Latitude E7240 (resolution 1920x1080). All the icons in the program have the form of the curve, the effect of the ladder. Will there be changes in this direction? Now use the tool simply unpleasant. -- CCleaner 5.03, Windows 7 SP1. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 24, 2015 Share Posted March 24, 2015 I'm not sure I follow the complaint, could you elaborate? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SAT31 Posted March 24, 2015 Author Share Posted March 24, 2015 I'm not sure I follow the complaint, could you elaborate? In the screenshot I showed the problem. What exactly is not clear? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 24, 2015 Moderators Share Posted March 24, 2015 Anything of your complaint is unclear. All I see is a screen cap of ccleaner 5.x which is known to have switched to a "modern flat" UI to follow suit with Microsoft's latest 2 operating systems. There is a dedicated sticky for this preferential disagreement, so if that is the case there's no need to make a nrw thread, just post your opinion on the UI there. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 24, 2015 Moderators Share Posted March 24, 2015 Complaints about the UI design are dedicated to only one topic located here, therefore this topic is closed: http://forum.piriform.com/index.php?showtopic=42323 Link to comment Share on other sites More sharing options...
