laozi Posted August 29, 2013 Share Posted August 29, 2013 bonjour, equal configuration: W7 32 bit ,browser (Chrome Version 29.0.1547.62 m), web page visited (http://www.adobe.com/software/flash/about/), to the closure of Crome appears in Ccleaner, Options, Cookies, Cookies to erase: macromedia.com -with CCleaner 4.04.4197 version of this file is deleted -with the 4.05.4250 version of this file is the only one not to be deleted precision, the two versions of Ccleaner have the same options checked the problem is not blocking just incomprehensible, hoping that the next version fixes this regression in my setup! apologize for my English cordially Link to comment Share on other sites More sharing options...
laozi Posted August 30, 2013 Author Share Posted August 30, 2013 hello, precision, 4.04 version over the scan cookies, analysis this site: C: \ Users \ Username \ AppData \ Local \ Google \ Chrome \ User Data \ Default \ Pepper Data \ Shockwave Flash \ WritableRoot \ # SharedObjects \ FJ3K952C \ macromedia.com \ support \ flashplayer \ sys \ settings.sol 1KB or is the famous macromedia.com file! the new version 4.05 zap this search to solve the problem, I added the part of Ccleaner, options include the following path: C: \ Users \ Username \ AppData \ Local \ Google \ Chrome \ User Data \ Default \ Pepper Data \ Shockwave Flash \ WritableRoot \ # SharedObjects \ *. * and everything is back to normal, cordially Link to comment Share on other sites More sharing options...
laozi Posted September 25, 2013 Author Share Posted September 25, 2013 hello, with the 4.06.4324 version, the problem is identical cordially Link to comment Share on other sites More sharing options...
xtremb Posted September 29, 2013 Share Posted September 29, 2013 (edited) this cookies is not delet with the 4.06 ! Edited September 29, 2013 by xtremb Link to comment Share on other sites More sharing options...
PinguJohn Posted October 5, 2013 Share Posted October 5, 2013 Having the same problem with CCleaner 4.06.4324 (running under Windows XP Home SP3) not deleting cookie macromedia.com even though both Internet Explorer and Google Chrome have Cookies ticked. Any help to solve this problem would be appreciated. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 5, 2013 Moderators Share Posted October 5, 2013 Having the same problem with CCleaner 4.06.4324 (running under Windows XP Home SP3) not deleting cookie macromedia.com even though both Internet Explorer and Google Chrome have Cookies ticked. Any help to solve this problem would be appreciated. If you click the cookie in ccleaner's cookies to remove/keep screen, what ifs the picture that is shown at the bottom of the screen. Do you have flash cookies checked in both the applications tab and also under the chrome heading? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
PinguJohn Posted October 5, 2013 Share Posted October 5, 2013 When I click the cookie in CCleaner's cookies to remove/keep screen, the picture that is shown at the bottom of the screen is a Google Chrome symbol and a Flash symbol followed by macromedia.com Cookies are checked in both the Windows tab under the Internet Explorer heading and the Applications tab under the Google Chrome heading. Link to comment Share on other sites More sharing options...
laozi Posted October 27, 2013 Author Share Posted October 27, 2013 hello, the 4.07.639 version still does not correct the problem of cookie macromedia a screenshot to show you the icon, greetings Link to comment Share on other sites More sharing options...
Guest MrT Posted October 29, 2013 Share Posted October 29, 2013 Hi, Do you have "Adobe Flash Player" checked under Applications->Multimedia? Thanks Link to comment Share on other sites More sharing options...
laozi Posted October 29, 2013 Author Share Posted October 29, 2013 hello, yes, Link to comment Share on other sites More sharing options...
Guest MrT Posted October 29, 2013 Share Posted October 29, 2013 Thanks, we'll look into this. Link to comment Share on other sites More sharing options...
PinguJohn Posted November 10, 2013 Share Posted November 10, 2013 Hi MrT For information, if I revert back to CCleaner 4.04.4197 then the chrome cookie macromedia.com is cleared. I note this is the last version before NVIDIA cleaning was introduced which may or may not be a coincidence. Look forward to this being resolved in future versions. Link to comment Share on other sites More sharing options...
laozi Posted November 25, 2013 Author Share Posted November 25, 2013 hello, problem solved with the new version 4.08 thank you Link to comment Share on other sites More sharing options...
