JohnBurns Posted April 19, 2013 Share Posted April 19, 2013 What's going on with this version? It was on FileHippo for download yesterday - now it isn't. I found it to be very, very slow and reverted back to ver. 2.13.670 yesterday. Now FH indicates 2.13.670 is the latest version. Am I confused or what? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 19, 2013 Moderators Share Posted April 19, 2013 No you aren't confused it does seem to have been removed. Also the build is gone from the Piriform site More info when we get some Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
jciiiab Posted April 22, 2013 Share Posted April 22, 2013 I would be interested in knowing what happened with Ver 2.14.705? I downloaded and started running Friday expecting it to shut down when completed as I was away for the weekend. Sunday it was still running at a little over 50%. Exited program... Uninstalled... Installed version 2.13.... Hope I have better luck. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 23, 2013 Moderators Share Posted April 23, 2013 the slow down bug was noted by the developers as a critical bug and the build was pulled. With apologies from the higher-ups. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 23, 2013 Moderators Share Posted April 23, 2013 Version 2.14.706 is now on the Piriform and Filehippo download sites Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Raym1234 Posted May 5, 2013 Share Posted May 5, 2013 I'm running 2.14.706 on a PC with an Intel Core i5 processor running WIN8. Started running Defraggler to defrag an external 2TB drive with approximately 1TB of files on it. It has been running all day and still reports 21 hours to go. Here's what's happening: one of the little squares turns yellow, then the external drive makes a thrumming noise for about 20 seconds (I assume it is writing data), stops for three seconds, and then the process repeats itself. Two naive questions: 1) is it normal for Defreggler to take that long to defrag an external drive and 2) is it safe for my external drive to be continuously writing for 40 hours or more? Link to comment Share on other sites More sharing options...
