Compare Posted December 18, 2012 Share Posted December 18, 2012 Please Help ! Ccleaner v.3.25 whit winapp2.ini v3.25.121212 Problem!? http://www.youtube.com/watch?v=KIL3FhjKO7M&feature=youtu.be What i can do it !? Link to comment Share on other sites More sharing options...
Compare Posted December 18, 2012 Author Share Posted December 18, 2012 Compare, on 18 December 2012 - 03:13 PM, said: What i can do it !? First, desist from double posts. Second, remove WinApp2.ini and try again. Then do NOT continue in this topic but continue with the topic you started at http://forum.pirifor...showtopic=37449 http://forum.piriform.com/index.php?showtopic=32310&st=2560 Download Ccleaner v.3.25 Prtable and install Download winapp2.ini v3.25.121212 and istall the same Problem! Link to comment Share on other sites More sharing options...
Alan_B Posted December 18, 2012 Share Posted December 18, 2012 Using the Portable is a good step. Please clarify. Does this only occur when WinApp2.ini is added ? Link to comment Share on other sites More sharing options...
Compare Posted December 18, 2012 Author Share Posted December 18, 2012 yes it is, only white winapp2! Link to comment Share on other sites More sharing options...
Moderators DennisD Posted December 18, 2012 Moderators Share Posted December 18, 2012 As your question is in the Winapp2.ini thread, I'll close this one. http://forum.pirifor...560#entry226800 EDIT: Just to clarify, as winapp2.ini is a user compiled add on, any issues with it can't really be described as CCleaner bugs, hence the suggestion to respond to the same question already in the winapp2.ini thread. Apologies for curtailing your help in this one Alan, but this hopefully prevents others with similar issues raising them as CCleaner bugs. Link to comment Share on other sites More sharing options...
