karrygun Posted July 25, 2012 Share Posted July 25, 2012 you can help me? add i cant defrag hiberfil.sys Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 25, 2012 Moderators Share Posted July 25, 2012 hiberfil cannot be defragmented. To get rid of its fragments turn off hibernation in Power settings then turn it back on ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
karrygun Posted July 26, 2012 Author Share Posted July 26, 2012 hiberfil cannot be defragmented. To get rid of its fragments turn off hibernation in Power settings then turn it back on how can I remove the hibernation? Then, I can turn it back subsequently? I can do a more thorough defragmentation, in some other way? with strings of commands? Link to comment Share on other sites More sharing options...
kroozer Posted July 26, 2012 Share Posted July 26, 2012 Cycle hibernation off and on with MS Fixits 50466 and 50462. or ► Start\Accessories\CommandPrompt\Run as Administrator To turn OFF type powercfg -h off To turn ON type powercfg -h on Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 26, 2012 Moderators Share Posted July 26, 2012 To defragment the MFT you will have to use another program like Ultradefrag. I hope Defraggler can include this feature in a near future. (pre-split quote) @eL_PuSHeR that was the op's question in may @karrygun, I'm going to split this from your old topic so people don't keep answering the old question @kroozer I didn't know about the fixits, thanks ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
