Coffee4Joe Posted May 24, 2012 Share Posted May 24, 2012 When trying to click a boot time Defrag Option (Run Once/Everytime) I encounter this: Tried: Running it as Admin Running the install as Admin Doing a clean install of Defraggler I'm getting it in both Windows 7 and xp Link to comment Share on other sites More sharing options...
D Bone Posted May 24, 2012 Share Posted May 24, 2012 Same here. W7 Home Premium x64 SP1. Link to comment Share on other sites More sharing options...
booknut Posted May 24, 2012 Share Posted May 24, 2012 Same problem here. Link to comment Share on other sites More sharing options...
D Bone Posted May 24, 2012 Share Posted May 24, 2012 That was a long time between updates, and I would've thought this bug would have been identified and fixed long before today's release. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted May 24, 2012 Moderators Share Posted May 24, 2012 The devs do read these threads guys, and can I ask if this is a 64bit related problem as you don't all mention what you're running? Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 24, 2012 Author Share Posted May 24, 2012 The devs do read these threads guys, and can I ask if this is a 64bit related problem as you don't all mention what you're running? Opps. I thought I put it in my first post Both XP and Win7 are running 32bit Link to comment Share on other sites More sharing options...
D Bone Posted May 24, 2012 Share Posted May 24, 2012 I doubt it matters, but I have UAC disabled on my W7 Home Premium x64 SP1 machine. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted May 24, 2012 Moderators Share Posted May 24, 2012 All info will probably be useful to the devs guys, so thanks for that. Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 25, 2012 Author Share Posted May 25, 2012 I tried saving settings to INI and enabling boot time defrag from that. The settings stay saved (until I tried clicking a boot defrag option then it reset back to 0) but it still won't preform a boot defrag. Using http://www.piriform....gglers-ini-file as a guide Tried both for NativeMode= Boot Time defrag run mode 0 = disable 1 = run once 2 = run everytime Also getting the Run as Admin popup after updating defraggler on a 3rd pc which has Win7 pro 32bit edit: attached log Link to comment Share on other sites More sharing options...
anuswara Posted May 25, 2012 Share Posted May 25, 2012 I confirm this issue after installing 2.40. I did run the application as admin and then I re-installed defraggler running the installer as admin. The same behaviour. I guess, the next release in June will fix this bug with the defrag (pagefile.sys and other files) at boot that cannot be selected in the settings men?. thanks. Link to comment Share on other sites More sharing options...
anuswara Posted May 25, 2012 Share Posted May 25, 2012 vista32 home premium sp2 see please this post http://forum.piriform.com/index.php?showtopic=35926&st=0&gopid=215220entry215220 Link to comment Share on other sites More sharing options...
eL_PuSHeR Posted May 26, 2012 Share Posted May 26, 2012 I have read in another post that this will be fixed in some June build. Link to comment Share on other sites More sharing options...
Super Fast Posted May 26, 2012 Share Posted May 26, 2012 Latest defraggler version fixed both issues I had. Post removed. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 26, 2012 Moderators Share Posted May 26, 2012 Super Fast can you post a separate bug report about the icon issue only in a new thread please to make it easier for the devs to spot it as this thread is about a different issue and a fix is already in the pipeline for it. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
eL_PuSHeR Posted May 26, 2012 Share Posted May 26, 2012 Mine has the usual icon. You mean defraggler.exe right? I am using the x86 flavour. Link to comment Share on other sites More sharing options...
Moonchild Posted May 28, 2012 Share Posted May 28, 2012 Re: Vista Home Premium 32bit As of Defraggler 2.10.413. Having the same issue as all of the others with the boot time defrag. Hope this will be fixed soon. Link to comment Share on other sites More sharing options...
John Spitzer Posted May 30, 2012 Share Posted May 30, 2012 Same Problem. Win 7 Ultimate 64x SP1 Link to comment Share on other sites More sharing options...
myteam Posted June 1, 2012 Share Posted June 1, 2012 When trying to click a boot time Defrag Option (Run Once/Everytime) I encounter this: Tried: Running it as Admin Running the install as Admin Doing a clean install of Defraggler I'm getting it in both Windows 7 and xp Same error here. Run with admin privileges. MS Windows 7 Ultimate 64-bit SP1 Windows Security Center User Account Control (UAC) Enabled Notify level 2 - Default Firewall Enabled Link to comment Share on other sites More sharing options...
sladek Posted June 2, 2012 Share Posted June 2, 2012 i have 7 home premium 64 bit and have same error - with admin account , same with right click and select Run as Admin and same with compatibility - Run as admin Link to comment Share on other sites More sharing options...
darren72 Posted June 4, 2012 Share Posted June 4, 2012 i have exactly the same problem.ive now uninstalled the program.ive gone back to using the windows in built tool. Link to comment Share on other sites More sharing options...
D Bone Posted June 4, 2012 Share Posted June 4, 2012 i have exactly the same problem.ive now uninstalled the program.ive gone back to using the windows in built tool. Not to pile on, and I know things happen, but I have done the same thing. I just can't help but wonder if something so obvious was missed in development, then what else was missed too. To be honest, I've lost a bit of confidence in Defraggler. Link to comment Share on other sites More sharing options...
scottls Posted June 4, 2012 Share Posted June 4, 2012 Trying to reinstall DF .391, had issues...!- http://forum.pirifor...showtopic=36014 Win 7 (x86), ESET Smart Security v8, Zemana Anti-Logger free and no other active anti-malware.Free on-demand- Old/fast MBAM v1.75 (No Pro/Context!), MBAM Anti-Rootkit BETA, Emsisoft Emergency Kit, herdProtect.i5-2500 CPU @ 3.67GHz, WD VelociRaptor sata6 10k rpm/64mb Cache HD (WOW!). Link to comment Share on other sites More sharing options...
tawd59 Posted June 9, 2012 Share Posted June 9, 2012 I've experienced the same problem but I have a problem w/ my restore points disappearing (all points) after a wipe- usually a three pass. XP home 32-bit tawd59 Link to comment Share on other sites More sharing options...
JTD121 Posted June 11, 2012 Share Posted June 11, 2012 Unfortunately, I have to report that 2.10.413 has this issue on Windows 7 Ultimate 64-bit. Any sort of timeline for the fix? Also, why is the disabled boot-time defrag a dealbreaker for some of you? I honestly have no problem with it being disabled temporarily, though I feel Defraggler is much better than even Windows 7s default defragger. I know for sure it's better than the defragmentation tool that came with Windows XP. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 11, 2012 Moderators Share Posted June 11, 2012 why is the disabled boot-time defrag a dealbreaker for some of you? because, sadly, for some people software must be perfect and always work without any bugs ever, else they throw their hands up and say "i'll never use this" that said, I agree that this should not be a "deal breaker" especially since this only is occuring on a single version and has already been slated for fix in the upcoming version. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
