Guest Keatah Posted November 29, 2011 Share Posted November 29, 2011 CCleaner, causes Microsoft Security Essentials to re-scan and report an un-protected system at startup; after you've run CCleaner. In my opinion (as a 30-year IT verteran), you should not mess with security products unless you know exactly 100% what the effects of your actions are. And Piriform obviously does *NOT* know that deleting logs will cause MSE to re-initiate a scan. With all due respect, get off your duff and fix this error. Also, as a "cleaning program" becomes more complex and handles more areas and files, it is important to tell the user what EXACTLY is being done. Link to comment Share on other sites More sharing options...
liju_cherian Posted November 29, 2011 Share Posted November 29, 2011 Hey Keatah, there is options to uncheck the things you don't want to delete.... check/uncheck the things and run. ----------------------------------------------------------------------------------------------------------------------------- Liju Cherian Dell Studio 1737| 3.2 GHz Windows 7 32 Bit | 4 GB RAM | 500 GB WD HDD | ATI Radeon 3600. ----------------------------------------------------------------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
Guest Keatah Posted November 29, 2011 Share Posted November 29, 2011 Yep. I do that for a few options. I just felt a little under the table because I recommended CCleaner and MSE a lot recently. And they don't play well together regarding that one point. To me it's not a biggie. But I like things to work smoothly for the folks I advise. Link to comment Share on other sites More sharing options...
nodles Posted November 29, 2011 Share Posted November 29, 2011 This has been talked about in many threads here: http://forum.piriform.com/index.php?showtopic=34329&st=0&p=205005&hl=mse&fromsearch=1entry205005 http://forum.piriform.com/index.php?showtopic=32981&st=0&p=204707&hl=mse&fromsearch=1entry204707 http://forum.piriform.com/index.php?showtopic=34449&st=0&p=206016&hl=mse&fromsearch=1entry206016 and there's more to find. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 29, 2011 Share Posted November 29, 2011 Side note: I don't have this problem. I constantly have MSE running in the background, and the logs are never actually removed. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted November 29, 2011 Share Posted November 29, 2011 Side note: I don't have this problem. I constantly have MSE running in the background, and the logs are never actually removed. Btw, if you stop the program/service, will it remove the logs then? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 29, 2011 Moderators Share Posted November 29, 2011 Just untick the "MS AntiMalware" box located in CCleaner's Applications tab. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 1, 2011 Share Posted December 1, 2011 Btw, if you stop the program/service, will it remove the logs then? Presumably, as they'd no longer be locked. I do not know why other people don't have the same locks on their log files. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted December 1, 2011 Share Posted December 1, 2011 In my view any Security software that does not lock and protect its files is make-believe. It is at best only suitable for supplementary on-demand scanning to identify what has already invaded and done its job Link to comment Share on other sites More sharing options...
frantim Posted June 12, 2015 Share Posted June 12, 2015 Just untick the "MS AntiMalware" box located in CCleaner's Applications tab. I have seen this advice a lot but I don't have a check box that reads "MS Antimalware". I only have "MS Management Console" and unchecking this box does not help. The only thing that seems to help is to turn off the real time monitoring of CCleaner. Does anyone have any better suggestions. Since this is an old thread maybe they changed the name of the checkbox. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 12, 2015 Moderators Share Posted June 12, 2015 Just untick the "MS AntiMalware" box located in CCleaner's Applications tab. I have seen this advice a lot but I don't have a check box that reads "MS Antimalware". I only have "MS Management Console" and unchecking this box does not help. The only thing that seems to help is to turn off the real time monitoring of CCleaner. Does anyone have any better suggestions. Since this is an old thread maybe they changed the name of the checkbox. You're replying to such an old thread that much has changed since the last reply in 2011; please start a new thread, and include vital details such as windows version and ccleaner version number. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
