Willy2 Posted October 12, 2011 Share Posted October 12, 2011 (edited) Came across another small (!!) text string bug in the latest CC v3.11. Here's how to find the bug. 1). Untick every box in the Windows and Application pane except for ""Adobe Flash Player"" in the ""Multimedia"" section in the Application pane. 2). Hit ""Analyze"" and then (hopefully) one line appears with a summary of files to be removed. CC clearly states ""(Note: No files have been deleted yet )"". 3). Click on the line that's being displayed and CC will display the details of the files to be removed. 4). If the user has one or more flash cookies then CC displays one or more times the text ""Removed cookie: "", followed by the name of the cookie/website. That text ""Removed"" VERY clearly contradicts the message displayed as mentioned under 2) (See above, in bold characters). The text string should be e.g. ""Cookie: ....."" or ""Flash cookie: ..."" before the user hits ""Run Cleaner"". And e.g. ""Removed cookie: ...... "" after the user has hit ""Run Cleaner"". Or perhaps CC should use a more neutral text like e.g. ""Cookie: ..."" or ""Flash cookie ....."" for the text that's being displayed both before and after the user will hit/has hit ""Run Cleaner"". Now when I am writing this, I have another suggestion for CC: 1. Let CC display an additional text something along the lines of ""Files to be removed :"" somewhere at the top of the screen that details which files are to be wiped. 2. Let CC display an additional text something along the lines of ""Files wiped"" or ""....... removed"" "" somewhere at the top of the screen that details which files actually have been wipe/removed. This certainly would reduce the remaining confusion, because now the user can - IMO - be confused whether files are actually removed or not. It's a confirmation at what stage CC is. Edited October 12, 2011 by Willy2 System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted March 30, 2012 Author Share Posted March 30, 2012 Piriform didn't adress this problem in the CC v3.17. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted May 26, 2012 Author Share Posted May 26, 2012 This error/bug hasn't been fixed in the latest CC version (v3.19). System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted November 8, 2012 Author Share Posted November 8, 2012 Still not fixed in v3.24. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted November 27, 2012 Author Share Posted November 27, 2012 Still not fixed in CC v3.25. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted December 23, 2012 Author Share Posted December 23, 2012 Still not fixed in CC v3.26. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted February 24, 2013 Author Share Posted February 24, 2013 Still not fixed in v3.27 System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted April 4, 2013 Author Share Posted April 4, 2013 Still not fixed in v4.00 System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 5, 2013 Share Posted April 5, 2013 This thread makes me sad, Willy winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators mta Posted April 5, 2013 Moderators Share Posted April 5, 2013 Gold Star for perseverance Willy. (reminds me of Shawshank Redemption - keeps writing those letters and the State will answer you - eventually) Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Willy2 Posted April 7, 2013 Author Share Posted April 7, 2013 @mta: I know for sure the Piriform developers are aware of this bug but they seem to have other things on their mind. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
TheWebAtom Posted April 7, 2013 Share Posted April 7, 2013 @mta: I know for sure the Piriform developers are aware of this bug but they seem to have other things on their mind. In fairness, a minor display bug that takes half a page to describe is never going to be considered a critical issue for any software project. I'm Shane. Link to comment Share on other sites More sharing options...
Willy2 Posted April 7, 2013 Author Share Posted April 7, 2013 What I have learned is that the most blatant bugs "get squeezed" first. The more a bug is "buried deeper" in the program code the more effort it takes to "uncover" that bug. And CC is in this regard no exception. Besides that, I presented two solutions for this bug. A simple one and a more elaborate one. The simplest solution would take the developers - IMO - less than five minutes to implement. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Willy2 Posted August 26, 2013 Author Share Posted August 26, 2013 Still not fixed in CC v4.04. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
nodles Posted August 26, 2013 Share Posted August 26, 2013 Do you mean v4.05? Link to comment Share on other sites More sharing options...
Willy2 Posted August 26, 2013 Author Share Posted August 26, 2013 Ooops, Yes, but in both versions (v4.04 & v4.05) this still hasn't been fixed. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
