octoberpiri Posted October 10, 2011 Share Posted October 10, 2011 Hello. I have used Defraggler in the past with no problems. Now the application crashes after using the "Analyze" function. Speccy.myCompy.txt = Log file (text format) from Speccy. Speccy.myCompy.xml = Log file(xml format) from Speccy. I am including the xml file because the text file stopped at line 558. Defraggler.exe.[2_7_346][2011-10-10_18-28].txt = The "/debug3" log from Defraggler. Note: I attached Speccy.myCompy.txt so that I can create a bug report in the Speccy section of the forum (I will link them here). Speccy.myCompy.txt Speccy.myCompy.xml Defraggler.exe.2_7_3462011-10-10_18-28.txt Link to comment Share on other sites More sharing options...
octoberpiri Posted October 11, 2011 Author Share Posted October 11, 2011 Solution To Issue: "chkdsk /f" I decided to try Windows Disk Defragmenter (I wish I had been smart enough to use it earlier). When I attempted to use Window's Defrag I received the following message: Disk Defragmenter has detected that Chkdsk is scheduled to run on the volume C:.Please run Chkdsk /f. I have rebooted several times since I 1st started having this problem. Chkdsk was not running at startup. I followed the advise given here: http://forums.cnet.c...102-186480.html. I rebooted, chkdsk ran. I am now able to use the Analyze function in Defraggler. Link to comment Share on other sites More sharing options...
eL_PuSHeR Posted October 12, 2011 Share Posted October 12, 2011 Glad to hear you sorted it out. Link to comment Share on other sites More sharing options...
