placido Posted August 15, 2011 Share Posted August 15, 2011 Hello, After my first cleaning with CC, opening any video is now impossible. What did the cleaning destroy that I could now re-install ?? Thanks. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 15, 2011 Share Posted August 15, 2011 (edited) Opening videos in what? VLC? WMP? Youtube? Which operation system do you use? Did you run the registry cleaner? What do you mean 'is now impossible?' what happens? Sorry to bombard you with questions. edit: ninja'd hazel Edited August 15, 2011 by Winapp2.ini winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 15, 2011 Moderators Share Posted August 15, 2011 Which operating system do you have ? Did you clean the registry? If you did clean the registry, did you make a backup? Are you able to right-click on a video and select 'open with'? EDIT... looks like Winapp2.ini and I ask the same questions Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Alan_B Posted August 15, 2011 Share Posted August 15, 2011 First guess has to be that you cleaned something vital in the Registry, and you only need to merge the backup REG file that was recommended default when fixing issues. Gosh - I was typing as fast as I could ! ! Link to comment Share on other sites More sharing options...
