ricktendo64 Posted March 6, 2011 Share Posted March 6, 2011 This has probably already been suggested but is there any way to add these 3 TMP files that are created in %WinDir% of XP? It has probably not been added because you guys may not be sure what the files are, but I did some investigating and they are nothing but CAT files that are already installed no longer needed. Here are the results (you can compare/verify the results yourself) ; XP SP3 Spanish SET3.tmp = SP3.CAT = md5: 6dda25bd2f3240a5c4fa68cc41cc88df SET4.tmp = NTPRINT.CAT = md5: 10d15250c354874754510a9e9617d243 SET5.tmp = IMS.CAT = md5: 721fdb6972400de8b18fdcac52bf6158 So please add these useless files for cleaning (maybe the temp cleaning function is a good place for it), it will save 2.24 MB of disk space tia Link to comment Share on other sites More sharing options...
ricktendo64 Posted March 24, 2011 Author Share Posted March 24, 2011 Bumb...hoping this will be taken into considerations, this has not been added yet (2.24 MB is allot) Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 25, 2011 Moderators Share Posted March 25, 2011 1. Open CCleaner 2. Click Options->Include->Add 3. Then add in each file and CCleaner will clean them whenever they're on the system. Link to comment Share on other sites More sharing options...
ricktendo64 Posted March 25, 2011 Author Share Posted March 25, 2011 I know how to add it to the program or to winapp2.ini, its just a suggestion for you guys I even cleared up any doubts as to what the files were in case you were worried about deleting something Windows "needed" Link to comment Share on other sites More sharing options...
