pepe2 Posted March 5, 2011 Share Posted March 5, 2011 Each time I open, for instance, a program. The '.exe unused registry keys' returns to the problems found during the registry scan. This issue came along with 3.04, no problems with it before that one. Link to comment Share on other sites More sharing options...
kroozer Posted March 5, 2011 Share Posted March 5, 2011 That's because V3.04 is more aggressive. Untick ☐Unused File Extensions. You may also right click items and add to Exclude List. Link to comment Share on other sites More sharing options...
pepe2 Posted March 6, 2011 Author Share Posted March 6, 2011 Pretty bad decision of the Piriform team if you ask me. The old way is way better, when it only scanned registry keys you actually don't have assigned to a program (like .DAT or whatever). Now it's giving me 'unused' registry keys even though they are assigned to different programs. Link to comment Share on other sites More sharing options...
redhawk Posted March 6, 2011 Share Posted March 6, 2011 pepe2 I'm having the same issues with CCleaner too it's detecting file types that clearly have programs associated with them. CCleaner = more aggressive?? I think more unreliable, buggy and destructive would be a better description for version 3.04. Richard S. Link to comment Share on other sites More sharing options...
dias Posted March 7, 2011 Share Posted March 7, 2011 pepe2 I'm having the same issues with CCleaner too it's detecting file types that clearly have programs associated with them. CCleaner = more aggressive?? I think more unreliable, buggy and destructive would be a better description for version 3.04. Richard S. I fully agree with Redhawk's last remark! Moreover if you try the solution given by moderator Twistedmetal, ("[solution] Registry Issues Keep Re-appearing In CCleaner"), going to the site of Dial-a-fix, will serious warn you with the following: "Dial-a-fix does not work with any Windows OS higher than Windows XP. This includes Windows Vista, Windows 7. Dial-a-fix also has a critical unpatched bug that will delete your C:\Documents folder." So, until CCleaner has been fixed in a proper way I will not use it on my Win7 64bits system! Dias Link to comment Share on other sites More sharing options...
pepe2 Posted April 2, 2011 Author Share Posted April 2, 2011 This issue has been resolved with the latest version of CCleaner. (3.05) Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 2, 2011 Moderators Share Posted April 2, 2011 This issue has been resolved with the latest version of CCleaner. (3.05) Not completely! It still detects other perfectly valid file extensions! Link to comment Share on other sites More sharing options...
