what is ".ink/openwithlist" ?
J?rn Rudolph
  • Moderators
That's in the registry cleaner, and it will probably endlessly reappear . What I've did since the new versions registry cleaner is more aggressive is exclude a bunch of the file associations (79 total) which it states aren't needed, however I know better.
You can exclude right inside the registry cleaner by right clicking and selecting: Add to Exclude list
Link to comment
  • Moderators
The Following site lists known Programs which use extention .ink
http://www.fileinfo.com/extension/ink
Do you now or have you ever had any of those installed.
If yes, and you no longer have the program it is safe to remove, else add it to the exclude list (right click and choose add to exclude)
Link to comment
  • Moderators
Doh Opps Lnk files are shortcuts add it to your exclude
(Thanks AndavarI you are my CPT Spectacular today :P)
Link to comment
Register a new account
Sign in
Important Information
