YTech Posted July 16, 2010 Share Posted July 16, 2010 Tested with 1.03.162 During Hard Drives Analyzing... Speccy is terminated with a Microsoft Visual C++ Runtime Library Error - Runtime Error! Nothing more is explained. There is two HDD installed, both configured as Master on both IDE controller. Primary Master MAKE: Western Digital CAVIER MODEL: WD102AA CAPACITY: 9.782/10.2 GB FILE TYPE: NTFS Secondary Master MAKE: FUJITSU MODEL: MPD3108AT CAPACITY: 10.0 GB FILE TYPE: FAT32 The Floppy Drive is disconnected and is disabled in the BIOS. Perhaps the issue is due to the Floppy Drive not responding. Following is portion of Speccy results that I was able to copy and paste. Operating System MS Windows XP Professional 32-bit SP2 CPU Intel Pentium III Cores 1 Threads 1 Name Intel Pentium III Code Name Katmai Package Slot 1 SECC2 Technology 0.25um Family 6 Extended Family 6 Model 7 Extended Model 7 Stepping 3 Revision kC0 Instructions MMX, SSE Bus Speed 99.6 MHz Stock Core Speed 550 MHz Stock Bus Speed 100 MHz Caches L1 Data Cache Size 16 KBytes L1 Instructions Cache Size 16 KBytes L2 Unified Cache Size 512 KBytes Core 0 Core Speed 547.7 MHz Multiplier x 5.5 Bus Speed 99.6 MHz Thread 1 APIC ID 0 RAM Memory slots Total memory slots 3 Used memory slots 2 Free memory slots 1 Memory Type SDRAM Size 512 MBytes DRAM Frequency 99.6 MHz CAS# Latency (CL) 2 clocks RAS# to CAS# Delay (tRCD) 2 clocks RAS# Precharge (tRP) 2 clocks Motherboard Manufacturer GATEWAY Model Maverick JN440BX Chipset Vendor Intel Chipset Model i440BX/ZX Chipset Revision C1 Southbridge Vendor Intel Southbridge Model 82371EB/MB (PIIX4E/M) Southbridge Revision 02 BIOS Brand Intel Corp. Version 4J4NB0X1.15A.0019.P11 Date 04/26/1999 Graphics Monitor Name Default Monitor on RADEON 7200 (Microsoft Corporation) Current Resolution 800x600 pixels Work Resolution 732x600 pixels State enabled, primary Monitor Width 800 Monitor Height 600 Monitor BPP 32 bits per pixel Monitor Frequency 60 Hz Device \\.\DISPLAY1\Monitor0 ATI video GPU R100 Device ID 1002-5144 Subvendor ATI (1002) Technology 180 nm Transistors 30 M Release Date 2000 DirectX Support 7.0 OpenGL Support 1.3 Bios Core Clock 166.00 Bios Mem Clock 166.00 Driver ati2mtag.sys (6.14.10.6462) ROPs 2 Shaders Vertex 2/Pixel 2 Bus Width 128 Bit Optical Drives MITSUMI CD-ROM FX4821T!A Media Type CD-ROM Name MITSUMI CD-ROM FX4821T!A Availability Running/Full Power Capabilities Random Access, Supports Removable Media Config Manager Error Code Device is working properly Config Manager User Config FALSE Drive E: Media Loaded FALSE SCSI Bus 0 SCSI Logical Unit 0 SCSI Port 1 SCSI Target Id 1 Status OK Audio Sound Card Crystal WDM Audio Codec Playback Device Crystal WDM Audio Recording Device Crystal WDM Audio Network You are connected to the internet Connected through D-Link DE-530+ PCI Ethernet Adapter - Packet Scheduler Miniport Piriform, please resolve this issue. Your product is looking great. Namespro.ca - goo.gl/9eoyWw - Canadian owned domain service provider. CIRA certified registrar.GTribe - PC Giveaway - goo.gl/LZPGRh : Preregister to be entered as they are announced. Many drawn this year. See you there! Link to comment Share on other sites More sharing options...
YTech Posted July 20, 2010 Author Share Posted July 20, 2010 The floppy drive and controllers have been enabled. The machine boots very well and runs smoothly. The Runtime Error! is still occurring. Namespro.ca - goo.gl/9eoyWw - Canadian owned domain service provider. CIRA certified registrar.GTribe - PC Giveaway - goo.gl/LZPGRh : Preregister to be entered as they are announced. Many drawn this year. See you there! Link to comment Share on other sites More sharing options...
