slowday444 Posted April 27, 2010 Share Posted April 27, 2010 Java Console, Java Quick Starter and MS .NET Framework Assistant? I'm trying to speed the startup of Sandboxed browser sessions on 32 Bit XP. I've gained about 10 seconds by disabling several I rarely use and am wondering about these. Thank You! Link to comment Share on other sites More sharing options...
redhawk Posted April 27, 2010 Share Posted April 27, 2010 10 secs from what?? Firefox usually loads instantly for me (from second run). Richard S. Link to comment Share on other sites More sharing options...
slowday444 Posted April 27, 2010 Author Share Posted April 27, 2010 10 secs from what?? Firefox usually loads instantly for me (from second run). Richard S. Sandboxed (Sandboxie)? Link to comment Share on other sites More sharing options...
Aethec Posted April 27, 2010 Share Posted April 27, 2010 Java Console, Java Quick Starter and MS .NET Framework Assistant? I'm trying to speed the startup of Sandboxed browser sessions on 32 Bit XP. I've gained about 10 seconds by disabling several I rarely use and am wondering about these. Thank You! Java Quick Starter >> Disable, unless you visit lots of websites that need Java. .NET Framework Assistant >> Never used. Disable. Java Console >> Unless you debug Java web apps, disable. Piriform French translator Link to comment Share on other sites More sharing options...
redhawk Posted April 27, 2010 Share Posted April 27, 2010 With SandboxIE 3.442 Firefox takes 8 seconds to load from cold and 5 seconds to load from a re-run. It's not exactly fast but still a reasonable loading duration considering the age of this PC. Richard S. Link to comment Share on other sites More sharing options...
JDPower Posted April 27, 2010 Share Posted April 27, 2010 Java Quick Starter >> Disable, unless you visit lots of websites that need Java. .NET Framework Assistant >> Never used. Disable. Java Console >> Unless you debug Java web apps, disable. Just to expand that a little - Java Quick Starter needs to be disabled from within Java (Control Panel>Java>Advanced tab, tickbox under 'miscellaneous'). The NET Framework requires a a little work to remove: http://support.microsoft.com/kb/963707 Link to comment Share on other sites More sharing options...
Aethec Posted April 28, 2010 Share Posted April 28, 2010 Don't remove the .NET Framework one - you don't know if you'll need it one day. Piriform French translator Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 28, 2010 Moderators Share Posted April 28, 2010 Don't remove the .NET Framework one - you don't know if you'll need it one day. I completely remove it, as in every trace on the system. The day I'd actually need that extension for anything whatsoever, probably never, which is why I also block it in Automatic Updates. Link to comment Share on other sites More sharing options...
Aethec Posted April 28, 2010 Share Posted April 28, 2010 I completely remove it, as in every trace on the system. The day I'd actually need that extension for anything whatsoever, probably never, which is why I also block it in Automatic Updates. Microsoft hasn't really chosen a good way to install it - but they wouldn't simply do that if it was useless. It adds ClickOnce support. Why didn't you simply disable it ? Piriform French translator Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 28, 2010 Moderators Share Posted April 28, 2010 Microsoft hasn't really chosen a good way to install it - but they wouldn't simply do that if it was useless. It adds ClickOnce support. Why didn't you simply disable it ? Simply because there was no option to opt out of installing it, which I never would have allowed if given the option. Link to comment Share on other sites More sharing options...
JDPower Posted April 28, 2010 Share Posted April 28, 2010 Don't remove the .NET Framework one - you don't know if you'll need it one day. There is absolutely no need for the .NET Framework Assistant in FF and it can be removed using the instructions given in the link I posted. It has absolutely no effect on the functionality of the .NET Framework itself. Link to comment Share on other sites More sharing options...
Aethec Posted April 28, 2010 Share Posted April 28, 2010 There is absolutely no need for the .NET Framework Assistant in FF and it can be removed using the instructions given in the link I posted. It has absolutely no effect on the functionality of the .NET Framework itself. It adds support for ClickOnce apps. Seriously, do you think Microsoft are so bad they would want to install an addon that does nothing ? Piriform French translator Link to comment Share on other sites More sharing options...
JDPower Posted April 28, 2010 Share Posted April 28, 2010 It adds support for ClickOnce apps. Seriously, do you think Microsoft are so bad they would want to install an addon that does nothing ? Have you ever come across a ClickOnce app? I removed the assistant on day one and have never had any page or app not work due to my Firefox's lack of ClickOnce support. There are lots of things you could install that add support for this that or t'other, should you install them all even though you'll never even see, let alone use, what they add support for though? Link to comment Share on other sites More sharing options...
Aethec Posted April 29, 2010 Share Posted April 29, 2010 Have you ever come across a ClickOnce app? I removed the assistant on day one and have never had any page or app not work due to my Firefox's lack of ClickOnce support. There are lots of things you could install that add support for this that or t'other, should you install them all even though you'll never even see, let alone use, what they add support for though? No. However, you can simply disable it - if you ever encounter a ClickOnce app, you'll be able to use it by re-enabling the addon. Piriform French translator Link to comment Share on other sites More sharing options...
JDPower Posted April 30, 2010 Share Posted April 30, 2010 No. However, you can simply disable it - if you ever encounter a ClickOnce app, you'll be able to use it by re-enabling the addon. Well if I ever come across one of these ClickOnce apps I'll simply install the .NET framework assistant, but until then I'm happy not having an unnecessary extension installed Link to comment Share on other sites More sharing options...
