Admin MrG Posted October 26, 2009 Admin Share Posted October 26, 2009 Windows 7 was released on October 22, and whether you're a new user or waiting with an older version of Windows, we've got new features and fixes for CCleaner that will improve your system optimization experience. We've made lots of other improvements which are listed below: CCleaner v2.25.1025 Improved Windows 7 jump list cleaning. Improved Windows 7 thumbnail cache cleaning. Added support for Windows Server 2008 R2. Improved 64-bit support and performance. Fixed issue with Windows 7 task scheduler. Fixed issue with Startup tool, displaying incorrect folder contents. Added support for AVG Antivirus 9.0. Added support for ExcludeKey in INI files. Improved support for wildcards and RECURSE/REMOVESELF. Fixed minor GUI bugs in non-English versions. Fixed minor GUI usability issues. Improved input validation. Lots of minor bugs fixed. Click here to visit the CCleaner.com site and to download View the full blog post Piriform.com - [CCleaner - Defraggler - Recuva - Speccy] Link to comment Share on other sites More sharing options...
warmth Posted October 26, 2009 Share Posted October 26, 2009 Thanks a lot MrG... working like never before @warmth Betatesting a life! Current: Nokia Lumia 920 [WP8], HTC 7 Surround T8788 [WP7.8] & Vodafone 858 Smart [Android SmartLucky2.3] | Previous: Nokia Lumia 820, 720, 800, E7-00, X7-00, N8-00, N97, N96, etc. Official Nokia Suite Beta Tester | Nokia Beta Labs Contributor of the month (June, 2011) | NokiaNews.eu & LoveMyNokia.com writer Link to comment Share on other sites More sharing options...
Moderators Andavari Posted October 26, 2009 Moderators Share Posted October 26, 2009 It will take some getting used to for me with the filelist display, however hold outs like I was that were sticking with v2.21 actually need to update now as the bug fixes make it very necessary, in particular: Fixed issue with Startup tool, displaying incorrect folder contents. Link to comment Share on other sites More sharing options...
JDPower Posted October 28, 2009 Share Posted October 28, 2009 It will take some getting used to for me with the filelist display, however hold outs like I was that were sticking with v2.21 actually need to update now as the bug fixes make it very necessary, in particular:Fixed issue with Startup tool, displaying incorrect folder contents. Nope, the new results is a major PITA and I'm still sticking with 2.21 in the (seemingly vain) hope that the devs will add the surely simple option of detailed list showing by default. How hard can a tick box be, or even simpler just have ccleaner remember previous view when closing? As for the need to update, every new release I download the portable version to see if, firstly, the above has been sorted and secondly, if there is any difference in cleaning/performance. v2.21 has no bugs that affect my use. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted October 28, 2009 Moderators Share Posted October 28, 2009 Nope, the new results is a major PITA and I'm still sticking with 2.21 in the (seemingly vain) hope that the devs will add the surely simple option of detailed list showing by default. How hard can a tick box be, or even simpler just have ccleaner remember previous view when closing? As for the need to update, every new release I download the portable version to see if, firstly, the above has been sorted and secondly, if there is any difference in cleaning/performance. v2.21 has no bugs that affect my use. You just right click a blank area of the results list and you'll see a detailed view. However I completely agree with you on the viewing option should be an option and remembered as a setting. As for bugs that don't affect you, well you never know for sure. 2.21 does have a critical bug in the Startup tool if you're missing your user profile 'Start Menu->Programs->Startup' folder. Link to comment Share on other sites More sharing options...
lifecaredelivered Posted October 31, 2009 Share Posted October 31, 2009 Thank You very much Link to comment Share on other sites More sharing options...
amandla Posted November 4, 2009 Share Posted November 4, 2009 CCleaner is so nice, I use it for a very long time and didn't know about forum. Today I found it and I am happy. It doesn't metter version is old or new it's best off all. Yes new version is better. I found today defragler and I'm happy. I'm happy that I became a part of this community. Whith warm fealings amandla Link to comment Share on other sites More sharing options...
JDPower Posted November 4, 2009 Share Posted November 4, 2009 CCleaner is so nice, I use it for a very long time and didn't know about forum. Today I found it and I am happy. It doesn't metter version is old or new it's best off all. Yes new version is better. I found today defragler and I'm happy. I'm happy that I became a part of this community.Whith warm fealings amandla Welcome to the forum Link to comment Share on other sites More sharing options...
Moderators DennisD Posted November 4, 2009 Moderators Share Posted November 4, 2009 A warm welcome from me too amandla. Link to comment Share on other sites More sharing options...
